new rear brake pads really dragging! FIXED
Old 10-14-2007, 02:08 PM
springerscott's Avatar
springerscott
springerscott is offline
Default new rear brake pads really dragging! FIXED
Just did front and back pads, rebuilt both calipers, and replaced rear master cylinder. Problem is rear pads are dragging on the rotor real bad. And rotor gets incredibly hot in two minutes of riding around the block. I pulled the caliper off, I can move the piston in by hand. Pads are wearing even and flat. What could the problem be????? This sucks!!!!
Old 10-14-2007, 02:27 PM
floydpink's Avatar
floydpink
floydpink is offline
Default RE: new rear brake pads really dragging!!!!!
I just had mine looked at after the rubbing was noticeable when backing up without the engine running.
The tech had a look and said it's perfectly normal, which I am not convinced is true. he said as long as it is wearing even, it is the way it should be. I left not convinced and will follow this thread for updates or thoughts from the senior riders.
Old 10-14-2007, 02:49 PM
HD7585's Avatar
HD7585
HD7585 is offline
The caliper slides back and forth on the mounting bolts...........remove them ,clean them ,and grease them..........then it will not bind and release easier
Old 10-14-2007, 03:33 PM
FastHarley's Avatar
FastHarley
FastHarley is offline
Former Sponsor
Agree with you. Brake pads should not get them hot. Mine do not get hot as I checked a while ago.
Old 10-14-2007, 03:39 PM
springerscott
the mounting pins are clean and lubed. The pads seem very tight on those metalmounting tabsyou use. I check everything again today. That wire retainer is on right too. No way are the pads supposed to get that hot.
Old 10-14-2007, 06:49 PM
cosmic kid's Avatar
cosmic kid
cosmic kid is offline
If the bike rolls easily in neutral, I don't see how it could be that hot. If it rolls easily in neutral, I'd probably drive it hotfor a while to see if itwon't start cooling off. If there's not any drag, I don't know what else it could be.
Are they the exact same pads that came off it?
Old 10-14-2007, 06:52 PM
cosmic kid's Avatar
cosmic kid
Have you pushed the bike with it in neutral. Standing beside it, getting it to where it is slowly "coasting" on it's own very slowly, getting a really good "feel" if there's a bind?
Old 10-14-2007, 07:13 PM
springerscott
Yeah there is a lot of drag pushing it in neutral, the pad are a quality brand but I forgot the name. The front doesn't drag at all.
Old 10-14-2007, 07:20 PM
shortfatboy's Avatar
shortfatboy
shortfatboy is offline
sometimes You have to remove the caliper pistons and clean them , then lube all the moving parts with brake fluid...sounds like the pistons binding.
Old 10-14-2007, 08:35 PM
cosmic kid's Avatar
cosmic kid
+1
If your sure the pads are the right ones (not thick than called for for your bike), it's gotta be a stuck piston.They've got to be reallyclean ,except for the fluid..(surgically?), any foreign matter at all, thatyou may not even see,can bind one
Quick Reply: new rear brake pads really dragging! FIXED
