new rear brake pads really dragging! FIXED
RE: new rear brake pads really dragging!!!!!
ORIGINAL: Scurvy Jack
You should also check that the plunger in the master cylinder is being pushed completely back out when you're off the brake. Even the slightest amount of pressure on the cylinder will cause the pads to ride on the rotor and overheat it.
ORIGINAL: HD7585
The caliper slides back and forth on the mounting bolts...........remove them ,clean them ,and grease them..........then it will not bind and release easier
springerscott
11-14-2007 09:22 AM
