How to wire a GPS on an '07 Softail Deluxe
Old 10-11-2007, 02:28 PM
fordma's Avatar
fordma
fordma is offline
Stage II
Default How to wire a GPS on an '07 Softail Deluxe
Is anyone able to give me some guidance on how to run the wiring for my Zumo 550? Where should I connect to and what's be best route for wiring. Should I lift the gastank and run the wires under it? If so, how do I loosen the tank? Any help is certainly appreciated!
Old 10-11-2007, 02:47 PM
Mike NY's Avatar
Mike NY
Mike NY is offline
Default RE: How to wire a GPS on an '07 Softail Deluxe
GPS?? Just wet your finger and follow the direction of the wind....
Actually, lifting the tank is easy. Just loosen the front bolt and Acorn nut and remove the screw at the other end where the seat rests on the tank. You will have to remove the seat first.
Mike
NY
Old 10-11-2007, 02:58 PM
Ratkiller's Avatar
Ratkiller
Ratkiller is offline
I think I would look into the wiring adapter HD PN#70270-04.
Ratkiller
Old 10-11-2007, 05:10 PM
SFarace20's Avatar
SFarace20
SFarace20 is offline
I spliced into the wires that power the front fender light onmy '03 Heritage, it works great!!
Old 10-11-2007, 07:42 PM
Mike NY's Avatar
Mike NY
Mike NY is offline
ORIGINAL: SFarace20
It may work great now but the wiring and fuse used for those type of lights is not made for addtional load usually. Not sure what the harness is that was mentioned above but it's usually better to wire things like that separatly right to the battery with a fuse.
Good luck with finding your way around !!!
Mike
NY
Old 10-11-2007, 09:53 PM
KWD FLSTC's Avatar
KWD FLSTC
KWD FLSTC is offline
5th Gear
When I wired mine up on my Heritage, I tapped into the "accessory" curcuit, which is the orange wire with a white tracer in the harness under the seat. No worries about overloading the circuit... it is a 15amp circuit, and from the factory the only thing on it is the intrument lighting, odometer, and front fender light on the Heritage. The Zumo pulls very little power - maybe 1 amp. You can also use the HD wiring adapter as suggested above, but the line that taps into is hot all of the time (which means you have to manually turn off the Zumo every time you stop), where the accessory circuit switches off with the ignition switch. I also lifted the tank so I could route the wiring right and zip tie it in place. Brought the end out under the bars to the Zumo mount. When you take the mount off you don't even notice the wire. Lifting the tank is a bit of pain but not too bad if you take your time. Good Luck!
UppercaseJC
03-24-2017 10:44 PM
OH Bob
06-27-2013 10:09 PM
slankard
01-10-2010 10:45 PM
DParker
03-25-2009 05:00 PM
BuckeyeHD
01-22-2008 03:27 PM
Quick Reply: How to wire a GPS on an '07 Softail Deluxe
