Autometer tachometer install
I have a 2004 HD Softail carb bike. I want to install a Autometer tachometer. Without screwing up the electrics, which wire (color) on the coil do I attach the green wire off the tach to, which wire off the ignition switch do I attach the red power wire from the tach to, and does the brown wire on the tach need to be cut? Is a 2004 HD Softail 1 pulse or 2 pulse ignition? thanks anyone
kimchek@vci.net
kimchek@vci.net
RE: Autometer tachometer install
I was able to install this tach with some internet work. Auto Meter was uninformed that our friends at HD had made changes removing the RPM (pink wire lead) from the wiring harness. I have contacted AM and am presently sending them info on what they need to tell their customers to install their tachs on 2004 or later bikes. A cheap $.95 part from HD # 74196-04 is needed and the info on how to remove wires from the speedometer connector. This info is in the 2004 Softail workshop manual from HD. Anyone who needs help on this install can email me. kimchek@vci.net
Kim
That info is available in the DIY section also, could have saved you some time here https://www.hdforums.com/m_65101/tm.htm
knightenforcer
Electrical/Lighting/Alarm
07-31-2014 04:42 PM
2004, 2005, autometer, davidson, harley, hd, install, installation, motorcycle, softail, sportster, tach, tachometer, wire, wiring
