refiling primary fluid
RE: refiling primary fluid
Onmy TC88B, both the owners and service manuals say to use 26 oz of fluid in the primary. Unless I am adjusting the clutch, I always fill the primary thru the inspection cover. Just use a measuring cup, fill it to the 26 oz mark and dump it in using a small, long barrelledfunnel I bought ateither WalMart or Autozone. Hell, I may have bought it at Alco...Doesn't matter where you get it...It's about a buck.I can'tsee spending that much on a derby gasket if I don't have to.
I guess the newer 07's darby cover is different in that it uses a captive O-ring type gasket.
I have a pump that I bought at W-Martto fill the lower uniton my Merc outboard motor. I use it to fill the primary and the transmission on my 2003 Heritage. I just look at the graduated lines on the container as I'm filling. The pump will screw directly to anyplastic oil container and it has a hose that will fit into the inspectionhole or the transmission fill hole. It costs about 15 bucks and doesn't make a mess. Well thats my 2 cents. I'm going ridin.
