Light bar on a Fatboy?
Old 01-27-2008, 03:44 AM
angelboy's Avatar
angelboy
angelboy is offline
6th Gear
Default RE: Light bar on a Fatboy?
So which kit is it that makes the lights look closer together?
I can't stand the wider option and I don't want to order the wrong one.
Also, having just read all the posts there's two different accounts of fitting. One where you remove the tank and the other where you dont?? Which is it?
To buy the kit from HD UK and have it installed in the UK I'm talking $800-$900 which is bullsh*t. I wonder if they'll pull the warranty card on me if I do it myself!
  #52
Old 01-29-2008, 02:29 PM
MICHALISLARNACA's Avatar
MICHALISLARNACA
MICHALISLARNACA is offline
The install is very easy provided you have the right one. There are two types. If you ride a 2007 on then you will need the new bar. The previous bar will only fit up to 2006
[IMG]local://upfiles/36097/B23FEAA716E7432BAEFE29EDDD7925DA.jpg[/IMG]
  #53
Old 01-29-2008, 06:36 PM
themensh's Avatar
themensh
themensh is offline
Wow, this IS an old thread....
anyhow, here is a pic of the 'bullet' spots on my 2000 fatboy.
Chuck
[IMG]local://upfiles/40791/C529B841D72444ED9A9971CEC11F1983.jpg[/IMG]
  #54
Old 01-29-2008, 07:15 PM
sonar_chris's Avatar
sonar_chris
sonar_chris is offline
ORIGINAL: themensh
Chuck
+1 on that, I started this threadover 2 years ago, but hey its still helping people. I now have the Aux light kit for Fatboy P/N
69287-07 and the Bullet turn signal relocation kit P/N 69079-04 along with the reflector lens lamps P/N 68348-05 and last but not least, the smoked turn signal lenses P/N 69304-02 and frenched trim rings for the passing lamps P/N69622-99Band headlight trim ring P/N 69627-99
Chris
Before trim rings
After Trim rings
  #55
Old 01-30-2008, 10:24 AM
VBFTuc's Avatar
VBFTuc
VBFTuc is offline
Just a note. I believe that if you think you might be adding a windshield, you need a different p/n light kit. I did my Fatboy 1 1/2 yrs. ago and as I suffer from CRS( Can't Remember Sh*t) I vaguely remember 2 different p/n's. I think there were different screws and spacers.
  #56
Old 01-30-2008, 01:08 PM
angelboy's Avatar
angelboy
angelboy is offline
6th Gear
ORIGINAL: sonar_chris
But these lights look too far apart for me.
Is the Deluxe kit closer together?
  #57
Old 01-31-2008, 05:14 PM
powaypete's Avatar
powaypete
powaypete is offline
Had a buddy's heritage behind me one night and could not see his stock turn signals flashing when he had his spot lights on. I went to the Kuryakan Turn signal mirrors and removed to stock signals. Gives the bike a retro look (no bulky turn signals) and they are bright too. I can see the reflection off the ground when I ride. In the back I went to strut mounted LED lights (yes they clear the Heritage saddlebags because they are mounted to the end and not the side of the render strut). Removed the 'ugly' turn signal bar. See the direction I'm going, RETRO. In my opinion, it really cleans up the bike and going LED, they really light up. Only problem is if a rider is behind me to the right, they can't see my left turn signal (and visa versa). When riding in a group, I use hand signals anyways.
Jimbojo
08-15-2014 07:21 AM
Jimbojo
Electrical/Lighting/Alarm
08-14-2014 08:14 AM
Gunnerthedog
08-05-2012 08:59 AM
scomike
03-12-2011 03:38 AM
steve.macinnis
02-13-2009 09:23 PM
Quick Reply: Light bar on a Fatboy?
