Need clarification on this...
Old 09-15-2007 | 12:09 AM
WARG's Avatar
WARG
Default Need clarification on this...
I did a search and think I understand, but correct me if I am wrong...
If I have a PCIII, I do not need the rev extend feature enabled if I already had a stage 1 download on my ECM right? Due to the download already increasing my rev limit to 6200 RPM. Is this right?
My dyno chart shows my A/F graph going up to 6200 RPM.
Old 09-15-2007 | 12:10 AM
anubisss's Avatar
anubisss
Default RE: Need clarification on this...
I think you are right. I have the same thing. Stage 1 download and a pcIII. The difference is I have never asked this question...
Old 09-15-2007 | 12:17 AM
HarleyWood's Avatar
HarleyWood
Thats correct. If your rev limit has already been increased and you have good values in the map fields all the way to 6200 you're set.
Ride safe
Old 09-15-2007 | 12:22 AM
WARG's Avatar
WARG
What do you mean?
Old 09-15-2007 | 12:23 AM
anubisss's Avatar
anubisss
You already have a higher redline than stock if you ahve the stage 1 download...
Old 09-15-2007 | 09:12 AM
WARG's Avatar
WARG
That's what I thought, the stage 1 download increases the rev limit so the Rev Xtend feature is not needed.
Old 09-15-2007 | 09:38 AM
HarleyWood's Avatar
HarleyWood
ORIGINAL: WARG
What do you mean?
On some PC maps there are zeros in the fuel cell fields above 5500 rpm, If the map you are running has numbers in those fileds than it was most likely setup on a motor that would rev to 6200 rpm.
Here is a cropped pic of a PCIII map, in the fields above 5500rpm its not adding or subtracting fuel, that doesn't mean it won't work. I just assume that the bike they used to create the map only rev'd to 5500..
[IMG]local://upfiles/4489/ED2F861A3DF04269B6E9BE590D15CF90.jpg[/IMG]
Old 09-15-2007 | 11:46 AM
WARG's Avatar
WARG
I understand, my bike was tuned on a dyno all the way up to 6200 rpm, so I should be set. Thanks for the clarification.
MrHog
08-17-2009 08:37 PM
mike06train
06-30-2009 05:52 PM
crackercap
03-20-2008 02:09 PM
classicglide
12-20-2007 09:00 PM
Parrothead
06-21-2007 02:07 PM
