Newbie with a ?
Old 09-14-2007 | 09:52 AM
Softcat07's Avatar
Softcat07
5th Gear
Default Newbie with a ?
Just introduced myself in the new member area and I have a ?.
I am going to install rear axle nut covers this weekend and wonderedif it matteredor not to have therear wheel off the ground to properly torque the rear axle nut? just curious..................
Thanks
Old 09-14-2007 | 10:29 AM
oldgeezer's Avatar
oldgeezer
Default RE: Newbie with a ?
If I understand what you are doing, you don't have to loosen the axle nuts, just the jam nut assembly. No need to have the bike on a lift but, depending on your set up,you may need to remove the pipes though.
Old 09-14-2007 | 10:58 AM
Softcat07's Avatar
Softcat07
5th Gear
The rear axle nut covers has a mounting bracket that goes behind the axle nut on left side and the axle head on the right side. These need to be loosened up tp slide the mounting brackets on. Then the coversgo on the mounting brackets with 3 allen head screws each side. (HD part # 47596-91B)
later
Old 09-14-2007 | 11:47 AM
oldgeezer's Avatar
oldgeezer
Sorry, the only ones I ever put on slid under the end of the swing arm, not the axle nut. Good luck.
Old 09-14-2007 | 11:53 AM
anubisss's Avatar
anubisss
Mine are held on a by a tiny allen head screw. Lazy man style...
Old 09-14-2007 | 12:43 PM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
ORIGINAL: anubisss
Mine too.
Old 09-14-2007 | 04:52 PM
mattyfatty's Avatar
mattyfatty
mine three
Old 09-15-2007 | 10:27 PM
jb55's Avatar
jb55
Softcat, I think we have the same ones. I beleive you are talking about the covers that are shaped like a triangle and cover the whole nut and adjuster. Harley makes them in chrome and black. I put the Black ones on my 07 FXSTC recentlly.I put a jackunder the rear frame so I could juggle every thing around.If your bike is new make sure you pay attention to the instructions where they tell you to replace one of the thick washers with a thinner one included in the kit [assuming it is the ones harley makes]
You will love the look in the end. The instal took no time at all.
JB
Old 09-16-2007 | 07:34 AM
Softcat07's Avatar
Softcat07
5th Gear
Yep JB those are the ones I installed, but chromeI did replace the thick washer with the thinner oneeven tho the directions said 2000 models only. I noticed the the cotter pin hole would not line up as good and tightening the axle nut to the torque spec still made ittight to get the replacement pin in. Iinstalled them Sat morning (9-15) and then went out and put 100 miles on, no problems at all.
I also put on new HD Skull series grips too, matches my pegs, shifter peg and rear brake pad. I am eventually going toinstall most of the skull series.
DarkManC
03-05-2014 08:31 PM
250REDNECK
03-15-2010 08:43 PM
TIPN8R
06-30-2008 07:24 PM
SgtThump
01-24-2008 07:11 AM
wadejesu
02-22-2007 07:04 AM
Quick Reply: Newbie with a ?
