Hissing noise
RE: Hissing noise
Someone is bound to chime in here that actually had this.... but if you do a search on here for it I believe there was a discussion about this and it turned out to be a line inside the tank on the fuel pump that was cracked open or had a hole in it. So the hiss is the pressure running thru the line.
RE: Hissing noise
I had a hissing noise coming from inside my tank when I would turn the RUN switch and the fuel pump would cycle.Turn out to be, as mentioned above, a hole in the fuel pick-up hose inside the tank. I mainly heard it before I started the bike, when the fuel pump cycled. Although I did hear it hissing while idling once. Took it in and the dealer fixed it under warranty, took them less than two hours on a Saturday.
RE: Hissing noise
Alright guys, thanks! Sounds like that what is going on. When I start the bike and the fuel pump cycles there is a loud hissing noise. I can now still hear it when my bike is running at idle. I guess I'll be breakin' out the service manual to figure out how to fix it. Thanks again!
RE: Hissing noise
ORIGINAL: WARG
If your bike is an 06, is it not still under warranty? Mine runs out in December. If so, let the dealer do if for free.
RE: Hissing noise
Got bike back today, it was a check valve assembly (62189-01A). Don't know if that is the same as the in-tank line or not, but it was fixed for free under warranty. Thank you guys for reminding me about my warranty, which happened to expire the day after I took it in, DUUUH!!
HRCH
07-06-2021 05:22 PM
