Void Warranty
RE: Void Warranty
When you replace factory parts with aftermarket parts, your warrenty is STILL INTACT. The only way a dealership can void your warrenty is by proving without doubt that the aftermarket parts installed were the direct result of another parts failure. In other words, if you install a new cam and your speedometer stops working, your speedometer is still covered under warrenty. Say you add new cams, and something in your transmission fails. Your still covered under warrenty, unless the dealership can prove without a doubt that the new cams were the result in the failure which is next to impossible.
And most time when you replace internal engine parts with quality aftermarket substitutes, you will have a seperate warrenty from the parts mfg. you purchased parts from. I had a couple of JIMS parts fail in one of my builds, I sent them the damaged parts and they replaced it free of charge. JIMS normally has a 6 month unlimited mile warrenty on their engine parts, and they are very quick to send out warrenty replacements.
RE: Void Warranty
ORIGINAL: dashiell
I'm reading from the 2006 HD Accessories book?
Page 513
Warranty: installation of AE products and or similar offroad (exhaust) or competition parts from other mfg's, except some "sreet legal" installed by auth. HD dealers may void your HD limited warranty.
Page 513
RE: Void Warranty
ORIGINAL: dashiell
Page 513
Page 513
The key word is "MAY VOID" your HD limited warrenty. And if you do some research by the laws set down by the government to PROTECT the consumer you will understand the guidelines which will void the warrenty.
The key guideline is that the manufacturer must prove without a doubt to a court of law that an aftermarket part was the sole reason for another parts failure on your bike.
RE: Void Warranty
ORIGINAL: Firefox
Right you are I bought an 06 nightrain and wanted to do a Screamin Eagle Filter, Exhaust (16 gauge one piece) and a Race tuner my dealer said fine but it will void your 2 year warrenty. So I thought this is nuts and I called and talked to a factory rep and he told me it depends totally on your dealer if they elect to cover it fine but if you purchase anything you purchase goes into the computer so if you purchase anything in the catalog with crossed flags or non street legal items it goes into the computer and if your bike breaks down somewhere else and they punch the vin # in the computer it will show it and if they elect to not cover it your screwed.
Do some research at places like the US govt website and the BBB which will go into detail on how the consumer really is protected.
RE: Void Warranty
HDMegaman is right, by law - If you've got the time and money to hire a lawyer and sue the dealership/HD. Most people don't have the means to go through all of that, so the dealers get away with screwing people over. Depending on what you want to do, the safe way to go about it is to order your parts online, so nothing is associated with your VIN. Install them yourself and put the stock parts back on if you need warranty service. If that's not possible, find a good Indy shop that's an authorized HD repair service. Most times they won't try to screw you around just because you've done a few mods.
I was even threatened with a voided warranty because I did my own 1000 mile service. It's insane. When I was given the lecture, I reminded the service lady at HD that I had purchased all my supplies from HD, I had my receipts and I had a record of everything I'd done. I asked her if using HD oil and filters typically voided the warranty, then I told her it was against the law to make a threat like that. She looked confused and I walked away.
