FLSTCI Oil Seeping
Old 09-11-2007 | 01:30 PM
fldave's Avatar
fldave
Stage III
Default FLSTCI Oil Seeping
I own a 2001 FLSTCI with 35k miles. Noticed oil on block behind cylinder
and was told it was a shift shaft seal. Had it replaced and still had the seeping.
On the second service call they found that it was oil seeping from the pry hold which
is cast into the engine cases. The hole was cleaned and filled with silicone which
appears to have solved the issue. According to the HD tech. this is the factory
fix.
djs
Milwaukee Eight (M8)
07-04-2017 07:43 AM
08ElectraNY
03-09-2016 09:32 AM
EW1959
08-15-2010 03:56 PM
Dallastx
08-21-2007 07:32 AM
HDF Tech
Engine Mechanical Topics
08-12-2005 10:07 PM
Quick Reply: FLSTCI Oil Seeping
