wireharness for 16in. apes
I'm finally sure of what size apes I want, 16's and was going to wait till winter before making the change but want to be sure on some things first. Has anyone installed on 16's a fatboy, using a novello harness? I searched around and it looks likea 12in. harness is too short, should I go with the 15 inch? . Also without having the bars in hand I might order +8 throttle/idla cable and +10 on clutch. Brake lines from HD. Also has anyone used polyurethane damper kit from Ness or J&P. Which works best for 06 stock risers. As always thanks for any help.
RE: wireharness for 16in. apes
I used the following for 16" Wild Ones on an '05 Fatboy with stock risers:
54" Brake line
44" Throttle/Idle
68 11/16" Clutch (wished I would have used a 70")
15" Novello harness.
I think as long as you buy poly bushing you will be good to go (I got a set off of Ebay).
Gonna take pics once the new tins are installed.
Good luck and have fun!
54" Brake line
44" Throttle/Idle
thanks. Its the small comments that keep the money flowing from my wallet the the parts people!
ORIGINAL: WARG
I just bought a spool of wire (16 gauge, I think) from the hardware store. Then I measured the length of the extensions out and soldered them onto the stock wireing .
Thanks all for the input. HD4me, might go with that same set up. How was it to disect the plastic connector, would you asy it cleans things up to use the novello harness? What do you think of the wild1's and 70 inch on the clutch huh. Please post pic with new tins must look sick
ORIGINAL: chop09
Just have fun with it and take your time.
