2000 Fatboy Harley Plug and Play Ape Hangers
Im having to remove the fuel tank as of right now. I’ve read around that on this model the plugs run right along the frame under the tank.
According to Hillside Customs, they are plug and play. First time buying from them so I’m not sure how reliable they are.
Do you mean Hill Country Custom Cycles in Texas....?? They specialize in full pre-wired kits of handlebar installs
Hill Country Customs has a good reputation. My riding buddy has used them on three bikes and likes their "stuff"...
Well, he DID like their stuff until a month ago..
We rode to Sturgis from SoCal.
On our last day there his hydraulic clutch cable, supplied by Hill Country Customs in a pre-wired handlebar kit, started leaking at the clutch slave. Due to the leak, he lost his clutch.
I was able to take everything apart, and found that Hill Country used a hydraulic clutch line with a swivel at the slave nut, versus a simple compression fitting like OEM and most other clutch lines I've seen. That high tech swivel is what developed a leak, with no way to fix it... I could have fixed a leaking compression fitting by buying a couple tools at a Home Depot...
To ad insult to injury, believe it or not, I could not find a hydraulic clutch line for a 2015 Bagger with 14" apes, anywhere in Sturgis...
I stood in line at the Black Hills HD parts counter for 45 min.... Twice... Once for them to give me the wrong clutch line (for an M8, not a Twin Cam). And a second time to return the wrong part, be told they did not have the correct part for a twin cam, and they could not check with any other HD dealer in the area to see if they had one in stock... Apparently they couldn't be bothered to check the HD parts computer.
None of the handlebar vendors, who had tents set up with multiple lifts that were installing bars left & right, said they had a clutch line to sell me.. Apparently if they help out someone who is stranded needing a clutch line for 14" apes, they may not be able to sell a set of 14" apes later on...
At least my buddy could take solace in his $1500 U-haul (to bring his bike back to San Diego) as he watched through windshield wipers while I got poured on in a rain storm in Northern AZ, and from the cool air conditioned cab as I suffered through 113° temps in the deserts just outside San Diego...
Anyways, I digress.....
At least Hill Country Customs is considered to be knowledgeable about what models need what connectors, and in spite of our experience with their hydraulic clutch line, they do have a good reputation for what they do...
Let us know what you find and how this works out....
eighteight (08-28-2024)
