Carb / Air filter issues
You sir, nailed it. I checked that the vent hole on the backing plate wasn't blocked before. But I never checked where it went, turns out the 90 degree flange just blocked it off from their own backing plate. Great design lmao. I just drilled a hole to feed it into the pipe on the flange. And my bike is running great now. You nailed it. Props bro
The following 2 users liked this post by Trumpet:
Dogs57 (07-29-2024),
MarlinSpike (07-28-2024)
Trumpet saved the day......
That's the problem with the cheap Chineseum copies without instructions..... there can be little things that can cause issues.
Luckily Trumpet had specific knowledge on that air cleaner assembly...
