'06 Nightrain gurgling sound in gas tank
After turning off my bike today I heard a hissing / gurgling sound on the bike. Took the gas cap off and I can see the gas moving slightly (tank is about 1/3 full) and can hear the hissing / gurgling sound as if there is a very small amount air getting into the tank through the gas line some how and bubbling up through the gas in the tank There is no gas leaking anywhere external of the tank. I also checked the bike an hour after turning it off and engine was relatively cool and STILL making the noise!
Would appreciate any ideas on what could cause this and what the fix would be.
Thanks in advance.
UPDATE - I checked the bike again after 3 hours . Still making the noise but I believe its the FUEL PUMP running while the bike is turned off. Totally bizarre. I have the bike on a trickle charger. I unplugged that, tried to start the bike and just got a clicking noise. Lights and signals work, but won't start. I'll disconnect the battery and reset the ECM (Thundermax) tomorrow and see how it goes. Feel free to offer up any trouble shooting thoughts!
Thanks in advance.
Fuel pump runs all the time when a FI is running. Holds 65 psi at idle or WOT.
Probably just bleeding off from the pressure relief. That relief housing can crack. The cap is one way vent in. The vent tube attached has a verticle restriction part. This keeps liquid from surging out.
Is bike running bad. If the feed pressure hose is cracked, idle since that is lean anyway will be first to go.
PS.. Welcome to the HDFORUM. Only as a suggestion, make another new thread over in the new member welcome area to say hello
Harley calls it a regulator. Item 5. Sounds like if fuel pump is running you have an issue with fuel pump relay sticking or ECM.
Parts come out of tank from the top with it on the bike if that really is your issue. Pull relay for pump to decide what noise really is.
When you start adding piggy back attachments, I'm no help for sure.
Jackie Paper (05-06-2024)
Thanks Foxtrapper. Will be checking this afternoon. I'll give updates after I determine source of problem. I believe it drained the battery yesterday as the bike would not turn over after the pump/regulator running for 2-3 hours after bike was off. After 1 hour I figured out it was an electric issue. Hopefully I can find the source today.
System relay gives power thru the 15 amp fuse only after ECM get the hits from crank position sensor (CPS)( ECM gives ground to magnetic coil in relay) Then you get running pump and ignition for spark.
The first couple seconds that you hear fuel pump when you key on is a timer in ECM giving power to the 15 amp fuse.
Doesn't have a BCM yet . That's around 2011? Please correct me if i am wrong.
