installing Chubby 504 bars??
RE: installing Chubby 504 bars??
I have them on my fatboy and all the cables worked just fine, but I changed mine out to braided stainless steel. If you ever plan on changein the cables out just go ahead and do it now, will make it much easier to do it all at once. They will fit just fine with all your stock stuff.
Chris
Chris
I had them on my Fatboytoo, really liked them alot. I was able to use the stock cables and lines but did have to rebend the brake line a bit to make it work. Did the internal wiring and chrome controls all at the same time, really dressed it up. Over stock length risers AND the 504's together might be a problem.
ORIGINAL: ronyd
Chris, did you install yourself? how long did job take? Not that it matters, since I'll do this over the winter...
Chris
FYI, Chooperdude gave me a great tip on the switch assembly cables. I removed the plastic conduit casing, and replaced with shrink wrap. Much tighter and was a breeze pulling though bars. Also recommended looking at HD part# 70017-06 ($.8.95/3 ft.)black mesh conduit to use over the wire harnesses coming out of from the bars to the frame. Pretty sweet....
Dam, just got some electrical parts (ie., relay and connector) for my Heat Demons circuit I'm putting together. Got them today, and was looking through catalog, and won;t you know it, they have what they call TechFlex Flexo Chrome, 25ft. froom $12 - $15 bucks (http://www.partsexpress.com). I spend $9 for 3ft of the HD black conduit I mentioned above. Check it out. I'll probably take back to HD and get the Chrome which will look nicer from the center of bars to the frame. Will match nicely with the Magnum Chromite cables.
