Custom Shift Lever Needed 2002 Deuce
Because of neuropathy my muscles that lift my ankle are weak. I have been using a heal toe lever on my Moto Guzzi with much success. Heal toe shifters for Forwards control pegs are rare nonexistent. I am looking at these two but I have not been able to confirm if the splines are the same if the splines are the same, I may be able to make something work Both of theses are for older four speed shovels
The V-Twin version looks like a copy of the Dewey Heel Hammer that is no longer available.
It might/might not work like you want.
Have you read this thread ? They replaced the mounts with those from a Heritage to get longer spline shaft
so that the 'traditional' softail heel/toe shifters work. Thread has some pretty good pictures too....
https://www.hdforums.com/forum/softa...e-shifter.html
good luck,
T.
good luck,
T.
good luck,
T.
good luck,
T.
I added the parts from that above mentioned thread, to give my 2001 Softail a heel/toe shift...
This is the result:
I put a heel/toe on my mid control '16 Low Rider. I used this Drag Specialties shift lever:
https://www.denniskirk.com/drag-spec...prd/579428.sku
The heel portion does bend outward, unlike the one you tried that is straight. I just don't know how the lengths will translate to your application.
Here is what it looks like on my '16 Low Rider
Deuce49 (02-01-2024)
The following 2 users liked this post by Deuce49:
blu92in99 (02-21-2024),
foxtrapper (02-21-2024)
foxbrow
03-16-2013 09:59 AM
