2007 Softail Custom bad gas
My neighbor has a 2007 Softail Custom that possibly has bad gas in the tank. His last fill was from a convenience store gas pump. He put about 20 miles on the bike and it started backfiring and such. The bike has EFI and a quick disconnect fuel line. When disconnected from bottom of tank - no gas comes out. He siphoned the gas out of the tank and put HEET in to mix with the remaining gas / water left in the lines. Bike would not start.
Any ideas as to next steps?
Thanks,
SUP
Thanks,
SUP
Bad gas ...
Thanks,
SUP
Thanks,
SUP
You could disconnect the fuel line from the throttle body and remove it completely. Then reconnect it to the tank with the hose pointed into a bucket. Cycle the key and let the fuel pump do the work.
Then fill with fresh gas and take it easy on the fuel additives. A bottle is usually enough to treat a full tank of fuel in a large car.
Now might be a good time to replace the crossover hose and the hose from the fuel tank to throttle body.
Thanks for the input. We checked and made sure the quick disconnect line was secure, tried starting with what seemed like an attempt to start and then nothing. Independent bike mechanic is going to check it next week. It may be a fuel pump going out and not bad gas. Bike will not start but does try just a bit but then does not. Fuel pump noise is very low. Bike has 136,000 miles on it.
I will update when we know for sure what it is.
SUP
SUP
hattitude (07-29-2023)
edilgdaor
04-13-2007 10:19 PM
