Kuryakyn Smoked rear LED turn signal conversion
Old 08-24-2007 | 01:22 PM
dmac1968's Avatar
dmac1968
Default Kuryakyn Smoked rear LED turn signal conversion
Just purchased the Kuryakyn Smoked rear LED turn signal conversion kit and it comes with some load balancer (or something like that from memory)... does this need to be installed on an 07 fatboy? What does it do?
If so, does it just plug in or is ita soldering iron job. Am guessing if it needs to be wired in that it gets wired under the rear fender. Does this mean that the rear wheel needs to come off?
DeanO
Old 08-24-2007 | 01:32 PM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Default RE: Kuryakyn Smoked rear LED turn signal conversion
It should have come with a sheet of directions on how to install everything.
But if it didn't just go to the Kury web site and you can download the directions in .pdf format from there.
Old 08-24-2007 | 01:42 PM
azmcdude's Avatar
azmcdude
Just installed the light on my Softail Custom......I ditched the rear turn signals so I did use the load equalizer....no soldering required...everything just plugs into place. Just had to find room....yet again...under the seat for the control module.
Old 08-24-2007 | 02:39 PM
ICEMANNN's Avatar
ICEMANNN
Mine is just plug and it work fine !
Old 08-24-2007 | 04:57 PM
Buddha4's Avatar
Buddha4
Keep and Eye on the LED's I had the Kuryakyn LEDS and got pulled over and the LEO indicated that over half the LED were not working. He was really pleaseant about the situation and wanted to let me know. That was the 2nd lense assembly.
Currently running HeavyCycles with the turn signals in the lenses. www.heavycycles.comMuch better quality and lifetime warranty.
Old 08-28-2007 | 03:44 PM
dmac1968's Avatar
dmac1968
Me too... just put mine on yesterday and they seem to work fine without the load balancer... but I won't be throwing it out, that's for sure... just in case!
DeanO
ORIGINAL: ICEMANNN
Old 08-28-2007 | 03:47 PM
dmac1968's Avatar
dmac1968
That sux... I thought LED's were super long life and reliable.I will inspect mine tomorrow. They don't seem overly water-tight. Also for the price, they would be very easy to pinch of your bike if parked ... literally 2 seconds.
DeanO
ORIGINAL: Buddha4
Old 08-28-2007 | 03:52 PM
JohnnyBoy's Avatar
JohnnyBoy
The Load Balancer is for the turn signals, not the brake light. Incadescent bulbs (regular bulbs) draw more current then LED types, so the Load Balancer is used to trick (or actually load) the system down. If you don't use it, your turn indicators have the potential of flashing at an unpredicted rate.
Old 08-28-2007 | 04:09 PM
dmac1968's Avatar
dmac1968
Yup... and the blink at normal rate, cancel etc etc all without the load balancer. I might end up putting it on anyway so I don't blow up any of the led's. Will that plug straight into an 07? Where abouts does it plug in?
DeanO
ORIGINAL: jfwarren1
ajm0442
Stock Harley Take Offs
04-22-2016 08:24 AM
santajim
Touring Parts
07-15-2014 11:21 AM
pstonge
07-01-2010 10:37 PM
radionightster
08-19-2008 01:31 PM
poonjahb
11-04-2007 04:48 PM
