V&H FuelPak Setting change that worked!
Hey Gang,
Notsure how manyfolks here have the V&H FuelPak (software version 12), I have been searching threads and trying to stay informed. There was some discussion about Mode 23 settings, and I found one that worked perfectly for me.
Less than 48 hours ago I had my stage 1 installed on the 08 FB. Since then, I have clocked 341 miles. At the recommended settings from V&H, and after personally verifying that my throttle-range readings were fine in Mode 21, I started re-tracing my favorate runs in flat Florida.
I was getting lots of gurggle and pops on the decel. Agreed- shorter pipes, and less back-pressure equals some normal gurgle and pops.
I then changed Mode 23 to a setting of 15. Pops and gurggle nearly gone!
The thread search results mentioned changing Mode 23 to one of two different settings. Folks have tried a setting of 50 and 15. V&H starts-off with a recommended setting of 16 for most configurations.
Mode 23 set to 50 didn't help me at all.
Mode 23 set to 15 made a BIG difference. Its been about 76 miles of running now with this setting, and I consider myself done with any further experiments.
Just thought I'd share with everyone.
RE: V&H FuelPak Setting change that worked!
Hi Poorboy
I have fuelpak on my 07 fatboy with BSS pipes
I got the stealer to put it all on for me at the beginning of the year
I too get lots of pops
How do I check my settings and how do I change them like you did to see what is best
Many thanks
Any info would be good
Steve in England
Many thanks
Steve in England
Hey fatboy40ate,
Click on downloads after going here: http://www.fuelpakfi.com/harley1.html
On the "downloads" page,look fortheFuelPak Installation guide for the Softails. This will give you step by step lessons for"navigating" the FuelPak buttons.
[ol][*]Once you have access to the FuelPak buttons, turn the bike's start/stop handlebar switch to the start position.[*]Turn your ignition switch to on. (don't actually start the motorcycle).[*]You should see your FuelPak LEDs say: _1 _0[*]You are looking at mode 1, with a setting of zero. Start writing down each mode and value assigned.[*]Depress the mode button again, you should see _2 _0 (again write these values down)[*]Repeat pressing the mode button and keep writing down your values.[*]Soon, you'll be at mode 23. Most likely you'll see a value of 16.[*]The instructions will describe how to change values (this is VERY easy).[/ol]
Write back if you get confused or can't get the guide downloaded. Depending on YOUR stage 1 mod specifics, this value change may help. If changing Mode 23 to a vaule of 15 doesn't help, try setting it to a value of 50.
You can get all this checked faster than it took me to write this all down. It is very easy and user-friendly.
Let us know!
Let us know!
Just getting back from my lunch time ride, I made some additional observations now that I have gone to value 15 in Mode 23:
[ol][*]The happiest lack of popping is when your hand has let the throttle twist all the way back to zero. In other words- no twist at all. The slightest throttle advance will give you those awful pops when you down shift.[*]I didn't realize how much my hand keeps some throttle on. That FuelPak is very sensitive to your throttle input.[*]If I completly let go of the throttle and JUST downshift, I don't get much popping at all, just gurggles.[/ol]
Before you guys make any changes, be sure to try this yourself on existing settings so you have a good before/after comparison.
Regards!
Regards!
