Fatboy fuel vent tube leaking
MarlinSpike (05-02-2023)
If you back pressurize the vent hose the only area where air should be exiting is at the small hole in the tank fill recess. If air is escaping the general fuel tank area this is a clue that theres an issue with that inner vent tube . (At least in theory i think this should be the case) . Keep us informed ! Maybe buy one of these bore scopes to visually see inside the tank. (I have one they are really handy )
https://www.amazon.com/Seesi-Endoscope-Waterproof-Inspection-Semi-Rigid/dp/B07PBF6DX5/ref=mp_s_a_1_3?crid=3TQF0HJP3OFI1&keywords=endosco pe&qid=1683120217&sprefix=endoscope%2Caps%2C169&sr =8-3
MarlinSpike (05-04-2023)
MarlinSpike (03-11-2024)
