Heritage Softail Accessories
Hi All! I am considering buying a 1998 Heritage Softail and I have a couple of questions I hope you can help me with on accessories of this bike.
First of all, what are these 2 gauges? One of those (the front one) is broken so I'll have to replace it, but I don't even know what that is for:
Also, is it possible to change the speedo to an original one? the one in this bike is not the original, it is a digital one and it is absolutely rubbish, I'd like to have the classic white speedo instead of this one, but I think I understand that you can't change the speedo without changing the mileage, cause the mileage is not saved anywhere in older HD models?
I still have to decide if this is worth buying or if I need to keep looking, I'll have to sell my Sportster XL883C first to get money to invest in this beauty.
The one on the left of your pic is just an oil tank dip stick with a thermometer in the cap... A quick check of oil temperature... if it still works. Those have the reputation of failing... often... just an FYI, that's also how you check your oil level... make sure to check it when warm... or some oil my be in the sump, rather than the tank..
The one to the right in your pic is an oil pressure gauge....
NDakota (06-26-2022)
It's not pristine, of course, but it's a 1998 model and has only 21K miles, running nicely. it has some age-related minors, but overall I'd say it's not bad. I really hope I manage to sell my Sportster before this bike gets taken!
Do you think changing the speedo is something I can do?
What about the mileage? will it stay the same? if I buy a used one for example, can I transfer the mileage into the used one?
The early bikes, like your EVO with a carb, were pretty simple and had an ICM (ignition control module).. the mileage was stored in the speedo... even the early ECMs (electronic control module) for EFI bikes, didn't contain the mileage....
Your EVO console is easily removed. You remove the one acorn nut (1/2" socket on OEM), and it will pull up and be able to lay on it's side... put something on the tank to avoid scratches...
There is usually a plastic ring with like three clips to release the speedo from the console. The online parts finder shows two electrical connectors and the odometer reset button, but that speedo part number on eBay shows only one electrical connector... Get a look at yours to make sure you get the right speedo if buying used...
If you get a used factory speedo (part #67027-96), you will need to find one with similar mileage.... As far as I know, there is no way to change the mileage. I believe the newest version is #67027-96C and it's obsolete, no longer offered by HD... so you'll need to buy a used one with close mileage or search for new aftermarket alternatives..
I changed the Speedometer on a 2001 Springer I bought. I bought the Springer about 4 years ago and it only had 9.8K miles... The card on the speedo face was badly faded, and I didn't want to pry open the speedo to change the card face.... I searched for awhile, but found one with like 500 miles more than I had on the bike. I bought the speedo and watched/planned my mileage carefully... When the bike had exactly 2 miles less than the odometer of the speedo, I changed them out.. I could have putted around the neighborhood to get the mileage even closer, but aI figured within 2 miles was close enough...
Good luck and report back how you replace the speedo...
Enjoy the new bike...!!
The following 2 users liked this post by hattitude:
eighteight (06-27-2022),
NDakota (06-27-2022)
