Laf pipes on 2013 breakout
I have a 2013 breakout fxsb fuel injected with vance and hines big radius 2 into 2. I was going to install laf pipes will I need to tune or have injectors switched out? Also I heard the old trick of a washer welded to a screw through pipe will do the trick for back pressure if needed any thoughts?
