Here we go again
Here we go again
Took the Scoot out for a 200 mile round trip, about 30 mins into the ride she started missing again. What are the chances that the TPS has gone out in under 1000 miles.
Same symptoms as before. I checked codes when i got home. P131, P151 AND P152. same codes as before. I have ordered a new TPS and will install in the next few days.
Just wondering if it was a fluk or why the TPS would go out again? 2007 Heritage Softail Classic.
unhooked the batter for about 30 mins, and also reset the TPS by turning ignigtion on and off.
started her up she coughed and died after about 20 sec.
started her again, it started and ran rough for about a minute, then died again.
restarted and she purred like a kitten.
Haven't taken it out yet due to a huge rain event. I will Post if its good to go or not when i get a chance to ride her.
Ok so when I bought the bike the gas gage was supper low gas light on but very much close to Empty. When I picked up the bike it was filled up for me. Come home bike starts the missing and coughing. Ended up changing the TPS and then all of a sudden it cleared up, she ran perfect.
FAST forward, last week i ran the bike pretty low maybe 1/2 gallon left in tank, way lower than i have ran it before.
I'm wondering if the filter might have picked up.some trash?
I've already ordered the kit to change everything except the pump itself. I did notice at times (last ride) the pump seems very loud. The parts should be here Monday, would a clogged filter make the bike run lean?
MarlinSpike (05-07-2022)
Two well known issues with the tank internals....
Pinholes in the internal fuel lines (often fuel pump to filter), and cracks in the regulator housing....
Sounds like you may be on your way to a fix....
