Rear Wheel Question
Rear Wheel Question
I recently bought my wife a 2004 softail standard that had the drivetrain from a 2007 night train installed along with tins. I am not sure if the rear swing arm was swapped too but it currently has a 200/55R17 tire on a solid wheel. I bought a contrast wheel from a 2006 night train but the hub appears to be wider (about 1/2”). The wheel did. It come with bearings, inner spacer, outer spacers, or pulley. Has anyone done this swap before? Looking for some guidance.
On the contrast wheel (Black center) that wheel was used on 2006 - 2009. I believe there were three variations of the same wheel, 2006 was different the the later (wider belt pulley), O7 was an odd year (narrower pulley) and 09 &09 were the same wheel. I tried to put an 06 on my 09 and it would not work because one side of the hub was wider than the later wheel. You may have a swing arm from a 07 - 09?
2007NT (03-20-2022)
I have touched the '07 & 08-later wheel, but Not a '06 wheel ... BUT I have handled the '06 spacer sleeve and know it's longer than the '07.
IF all your wheel size difference is on the Pulley Side, check to see if there is enough "meat" on the pulley to mill off the same amount of difference.
... haven't looked up associated parts interchangeability yet
That was kind of my thought. Either take material off the hub or the pulley.
If I knew the spacer lengths for the 06 I could confirm this but not sure if the swingarm from a 06 and 07 are the same.
Op a minute of your time please
I am wanting to do to my 2004 exactly what your taking off from yours if you get some time could you let me no what all was changed from the 04 to allow that wheel to fit I’ve had people tell me just the bearing, and others tell me all the way up to swingarm and fender but any advice would be greatly appreciated
YeaThatsMe (03-07-2024)
