High Idle
Old 11-10-2005 | 12:37 AM
dukmn80's Avatar
dukmn80
Default High Idle
Hey guys, On my '02 Fatboy efi the idle stays pretty high when I slow down fast. It's not like it's anywhere near redline or anything, but it is definatley high. After I get stopped the idle comes down. But I don't know what the deal is. Anyone have any idea?
Old 11-10-2005 | 01:59 AM
Mike05's Avatar
Mike05
Default RE: High Idle
... Just some thoughts ...
I'm not versed very well in the EFI department even thought I have an 05 Heritage EFI. Could it be the throttle position sensor? I'm pretty sure the EFI models would have one as the electrical system needs to know the throttle position for fuel delivery, timing etc ... Could be it's hanging up a bit ... Or could be a return spring or something along that line ... Maybe some Dri-Slide on the pivot points, springs or whatever would help ... I believe you could check the electrial function of the sensor with an OHM meter, but I would check with someone in the know first
Good Luck
Old 11-10-2005 | 04:07 AM
Taildraggerdave's Avatar
Taildraggerdave
Mine does that sometimes....will idle around 2000 for a moment before it settles down. Not sure what it is. So far, I've ignored it. Maybe someone will have some input.
Old 11-10-2005 | 04:42 PM
Loanshark's Avatar
Loanshark
Mine does that too. I notice it more if I've stopped for gas or something, then start up and take off quickly, the first stop I come to it'll be idling @ what I would guess to be around 2000 rpms the if I stay stopped for a couple of seconds it goes back to normal. Hasn't caused me a problem, it doesn't sound like a carbed bike, but it sure does run smooth.
Bogey_52
12-01-2016 11:08 AM
bkessler28
05-18-2013 01:25 PM
jlasoftail
Exhaust System Topics
08-09-2012 01:49 PM
onaride63
08-03-2010 04:14 PM
Slyde
11-28-2007 03:35 PM
Quick Reply: High Idle
