Oil Cooler
Old 08-10-2007, 07:09 PM
mori55's Avatar
mori55
mori55 is offline
Default RE: Oil Cooler
I put the premium cooler on my Deluxe and it didn't make much of a diierence at all. Can't see how it gets much air with that big fender right in front of it.
Old 08-10-2007, 07:59 PM
IsurvivedNMU's Avatar
IsurvivedNMU
IsurvivedNMU is offline
ORIGINAL: SEDONAMAN
OVER 230 IS BAD
Where did you get that info?
The harley cooler has a thermostat that opens at 220.....
How and where are you guys taking your temps? I have a Harley temp oil plug in mine... I have yet to see it over 220 without the cooler... Although i like the idea of a cooler... you never know if you will get in stop and go traffic... The 07 models will shut off the rear cylinder if they get too hot, but only at idle... anyone had this happen?
Old 08-10-2007, 08:17 PM
macdracer's Avatar
macdracer
macdracer is offline
Have an 07 Deuce here and riding stop light to stop light in 90+ weather (not this week 104, yikes) and I've not heard the cylinder cut out yet. I also read somewhere that the first thing the 07's do is lower the idle at a certain temp, but I've not had that happen yet either.
Old 08-10-2007, 08:34 PM
Soft06's Avatar
Soft06
Soft06 is offline
[quote]ORIGINAL: IsurvivedNMU
ORIGINAL: SEDONAMAN
OVER 230 IS BAD
FYI Well, you're wrong about the thermostat opening at 220..
Premium Oil Cooler Kit
This cooler was designed specifically for Harley-Davidson® to out-perform all other coolers in the industry. This cooler features a unique "Turbulator" system that evenly distributes oil across the cooling chambers. The air fins are designed to efficiently dissipate heat. This popular Touring oil cooler has been re-designed to simplify installation and enhance performance. The larger heat exchanger provides additional cooling efficiency. Kit features an adapter plate with integrated thermostat that allows oil lines to connect to the oil filter bracket. The thermostat activates at 185°F (85°C). Kit comes complete with mounting hardware and precut oil lines. Kit includes Chrome Oil Cooler Cover.
Just sharing facts....
Old 08-10-2007, 09:19 PM
site351's Avatar
site351
site351 is offline
If the one in your Pic is the PREMIUM oil cooler....than thats the one
I have...glad you posted that info......
Old 08-10-2007, 09:23 PM
Speedkingnick's Avatar
Speedkingnick
Speedkingnick is offline
I also have been contemplating an oil cooler - however I want performance with it not looking gawdy.
I know many of you have installed the Harley Davidson Premium Kit:
However I have seen others such as this Billetcool one where the oil filter mounts on the outside of this one:
and then there is this Harley Davidson One that fits over the oil filter:
Then the Jagg one mounts on the outside of the frame (not pictured)
SO which one would look good.....
That is the bazillion dollar question.
Old 08-10-2007, 10:08 PM
Peg_legs's Avatar
Peg_legs
Peg_legs is offline
It appears that you have crash bars. Check this out https://www.hdforums.com/m_67156/tm.htm
big fenders won't get in the way, and cheap
Old 08-10-2007, 10:43 PM
BarryN's Avatar
BarryN
BarryN is offline
Had anyone took the temp prior to putting a oil coolier on and checked it again. Would be interesting to see how much it lowered the temp.
Old 08-11-2007, 06:33 AM
IsurvivedNMU
My bad on the oil cooler thermostat temp.... I had read that 100 times... and the dealer I was at yesterday read it to me and said 220.....
I see 250 alot on the sportster... maybeI should think about a cooler for it.. that bike is driven hard with a lot of mods....
pauletich
09-20-2010 05:37 PM
pauletich
08-05-2010 10:18 AM
mnharleyrider20
03-18-2010 06:00 PM
Sancho
01-17-2010 08:42 PM
BIGUNXXL
03-30-2008 08:17 PM
Quick Reply: Oil Cooler
