Tombstone tail light for 2008 heritage softail
A lot can be learned by doing a simple comparison with part numbers over at Ronnie's microfiche. With a little digging I came up with this for you.
One is an 08 Deluxe Rear Fender assembly the other is your 08 Heritage, if you look at the chrome supports and the fender supports you'll find identical part numbers.
This tells me an 08 Deluxe fender will mount right up to your 08 Heritage. Therefore giving you the ability to go with a Tombstone taillight, but the cost could be high, I
don't know of anyone that makes an all in one Brake/Turn/Run Tombstone Taillight, but then I never looked. You go Tombstone in the rear you're going to need turns
also. That would require this. Ronnie's Harley-Davidson's 2008 Harley Davidson FLSTN SOFTAIL® DELUXE (JD) | TURN SIGNALS - REAR Parts List (onlinemicrofiche.com)
And your front turns will not match your rears. But there may be more to it. Hope this helps, a little bit.
Ronnie's Harley-Davidson's 2008 Harley Davidson FLSTC HERITAGE SOFTAIL® CLASSIC (BW) | FENDER - REAR W/ SUPPORTS Parts List (onlinemicrofiche.com)
Ronnie's Harley-Davidson's 2008 Harley Davidson FLSTN SOFTAIL® DELUXE (JD) | FENDER - REAR W/ SUPPORTS Parts List (onlinemicrofiche.com)
Received 4,213 Likes
Check the part numbers, but probability is high that a 2008 Deluxe rear fender will bolt right up.
I changed my 2012 Heritage Rear Fender with a 2012 Deluxe rear fender. Also had to do some wiring harness changes.
I am really happy with how it turned out.
LINK to a Report with more details and photos.
__________________
Win Up to $350.00 Cash from DK Custom This Month, Click HERE to see How!
DKCustomProducts.com
Tampa, you have a Deluxe, he has a Heritage, looking to go Deluxe style Tombstone taillight.
Big difference.
Big difference.
It's exactly what DK said and I said prior, check your numbers, more fits then you would think. I'll keep my lollypops front n rear.
JUst givin another insight what can be done.
I grew up shipyard, machine shop available my off hours. Make anything. Just sayin.
Hands on, a lil labor, and the machine shop, you have that deleuxe tombstone/light bar and tag below it.
It's all about whaat you put into it, that tlc. Simplest way throw a deluxe fender on, yes. Have to have it painted tho, do what I suggested...DIY on your own fender with the deluxe lightbar/tag/tombstone.
