Heritage Passing lamps HELP!!!
Old 08-11-2007 | 09:02 PM
Chief101's Avatar
Chief101
Default RE: Heritage Passing lamps HELP!!!
Try this post for the passing lamp info:
https://www.hdforums.com/m_54142/tm.htm
Let us know how it works out!!
Old 08-11-2007 | 09:58 PM
gconklin's Avatar
gconklin
ORIGINAL: coolrays615
Actually, I'm looking for a link for his triple pole light switch. The wiring isn't difficult, but getting a switch like he described would be awesome!!
Old 08-13-2007 | 02:07 AM
Nasty350LT1's Avatar
Nasty350LT1
Is the switch a DPDT or a SPDT ?
Also are those 2 connectors in the headlight housing,
or do I have to take apart the front of the bike ?
Need more information, please
Old 08-13-2007 | 10:31 AM
gconklin's Avatar
gconklin
Single pole, but there'd be three connections to choose from, so would that be a triple throw?
Sorry for my lack of knowledge here...
Old 08-13-2007 | 10:58 AM
HarleyWood's Avatar
HarleyWood
ORIGINAL: gconklin
The switch he is referring to would be a DPDT switch. ON / OFF / ON. Since thre is two different sources for the power it will have four connections for the wires (two circuits)
its a common item at any of the discount auto houses like advance or pep boys for about 6 bucks
Old 08-13-2007 | 11:59 AM
gconklin's Avatar
gconklin
Ooh... I musta misunderstood the description then.
I'm actually looking for a switch that has three positions, none of them being OFF.
1) low beams w/out modulating spot lights
2) low beams w/ modulating spot lights
3) hi beams w/out modulating spot lights
Old 08-13-2007 | 12:03 PM
JBaker421's Avatar
JBaker421
Big Kahuna HDF Member
Why couldn't you just pick up an additional circuit(power) from the high beam circuit? The passing lamps might blink a bit when switching, but they should stay on?
OK, I know, don't know what I'm talking about, lol.
Old 08-13-2007 | 12:23 PM
gconklin's Avatar
gconklin
not sure about them, but I'm talking about making three settings, not just the two we have on the stock switch.
Old 08-14-2007 | 03:02 PM
chuck_112252's Avatar
chuck_112252
Stage III
2006 Hertiage Softail Classic
I'd like to know if there is another light with more candle power to replace the stock headlight.
Old 08-14-2007 | 03:52 PM
gconklin's Avatar
gconklin
chuck, are yours 50w? You could investigate the 100w hi-output bulbs. Though be warned, I hear their heat output is so high that some consideration should be put towards it; ventilation for instance.
My stock candescents are only 35w I believe, I need to at least move onto halogen.
Quick Reply: Heritage Passing lamps HELP!!!
