2012 FLS Ape question
I just got a 2012 FLS(with abs) and I’m looking to put a set of Todd’s cycles 10” mini apes on it. Of course I decide to do this after I had everything off when I changed the handgrips and brake/clutch levers😵💫. I’m wondering if any of the cables need extensions for this setup? If so, what did you guys use for parts specifically? Stock cables seem to have a lot of slack but I’ve been eyeballing that abs cable…🤔
12FLS12ZX10R (05-13-2021)
@sinthroid
Your bike looks great! Now I know what mine will look like-same color too. I just took everything apart but hit a dead end when I got to the electrical part. The wires connect somewhere under the tank I think and I couldn’t follow them back anymore unless I took the tank off. Does that sound about right?
well my bikes older, but i'm 3/4 done doing my swap to todd's 10 inch
i got the kit from hillside pre wired.. comes with everything
cables, brake line, wires ran through the bars,switches and housings.. and new connectors and for me throttle cables
i did that route cause soldering all them would have been a pain.. and my housings were pretty beat so
bit pricey but saved me from doing it from square one
Do yourself the favor, buy the proper length cables, for all applications. NAMZ makes extensions for the electrical part and from Barnett you‘ll get clutch and gas cables to your precise length. The stock cables may look like they fit, but with the higher bars there will be more strain on it and at some point e.g. the nipple on the clutch cable will break where it attaches to the grip. Usually when you are far from any dealer...
best, niv
best, niv
