Sound from TC88b
Old 08-03-2007 | 08:21 AM
Drain_Plug's Avatar
Drain_Plug
2nd Gear
Default Sound from TC88b
Does anybodys engine have a sound like a roller bearing spinning. I'm getting this sound from my engine,
the dealer thought it was one of the front balancing shaft bearings. They were good about it and changed
both front and rear bearings but I still hear this sound. Not as bad as it used to be at idle, this noise did not
appear untill I had just under 4000 miles on it. I can hear it good over the sound of my pipes when going
down the road ( v&h stright shots w/h ).
Thanks Steve
Old 08-03-2007 | 06:05 PM
mr.hammond's Avatar
mr.hammond
Default RE: Sound from TC88b
hmm.
Old 08-03-2007 | 11:32 PM
Speedkingnick's Avatar
Speedkingnick
Check the primary chain. You may also need cam chain tensioners - usually you need to replace them around 20,000 miles. You can only look at one through the inspection cover - there are 4 total. You have to disassemble quite a bit of stuff to inspect the other ones - I changed over to gear drive - eliminates the chain and gives you 5-10 HP.
Old 08-04-2007 | 07:16 AM
20NightTrain03's Avatar
20NightTrain03
if you changed to gear drive you would know that there only TWO cam chain tensioners...........not the four as you suggested
also, i have 22K miles on my motor, have about 85% left on the shoes
not trying to pick, just help others
Lotaluck
10-29-2017 08:18 AM
AllenG
09-24-2013 08:58 AM
AllenG
09-24-2013 12:28 AM
WTFMike
03-07-2013 04:35 PM
clap
05-14-2006 04:40 AM
Quick Reply: Sound from TC88b
