Clutch adjustment - jam nut difficult to remove
Hello. I have a Softail FXSTS 2004. While doing my primary chain oil change I wanted to adjust my clutch. I tried to loosen the jam nut with a combination wrench while holding the center Allen screw. No luck! If I continue I will strip the jam nut.
I loosened the clutch cable completely. Tried depressing the handle a few times to get the clutch plates to move. Still no luck!
any suggestion how I can get this out? Maybe a better tool? Any help would be appreciated!
thanks.
thanks.
bikefxds (04-04-2021)
headbanger8383 (07-18-2024)
Cheers!
NO you do not have to use an allen to keep the adjuster rod from moving when loosening the lock nut.
YES you need to make sure the transmission is in top gear (5th) and make sure the rear wheel is on the ground.
The hissing you hear is the pistons rising because the bike wasn't in top gear, the transmission has a leverage and the rear wheel might not be supporting the bikes weight.
Google "craftsman dog bone wrench". The six sided version is perfect for clutch adjustments, the allen will fit thru it. Or, you can use a 60 degree offset box end, a six point works best because it contacts the flats, not the points. Personally, I use a Snap On 60 degree, six point 11/16".
The following 2 users liked this post by Campy Roadie:
Long lonesome highwayman (03-29-2021),
S.D.M.F (03-28-2021)
Campy Roadie (03-28-2021)
