03 Softail Deuce Crankshaft Sensor Connector
Hey everybody, help me locate where the Crankshaft Sensor connector is located. The service manual says it is behind the voltage regulator, but when I look, I think it runs the whole way to the computer? What gives? The only replacement I find is the short 6 inch sensor?
It's #8 in the diagram...
It's the thing that always gets in the way when you chnage the oil filter....
Thanks for replying. I am having a hard time understanding where the end connection is. Harley says I need a 5” crankshaft sensor and it looks a lot longer then that to connect it up properly. Does this 03 have to be spliced in?
I haven't had to change one yet... but I don't believe any splicing is needed... follow the wire...
Here is what the part looks like
On both my softails, an '01 w/carb and '03 EFI, that connector is on the engine side of the bracket (#10) where the voltage regulator is mounted, next to (and above) the voltage regulator (#20) & Stator (#21) connector....
Looks to be a simple mount, plug, and play replacement..
Mikemetal
Exhaust System Topics
08-12-2019 11:37 PM
bartallica2006
07-24-2012 11:21 PM
