Flush Mount (popup) Fuel Cap and Gauge Install
Old 07-29-2007, 02:42 AM
doc_cj's Avatar
doc_cj
doc_cj is offline
Default Flush Mount (popup) Fuel Cap and Gauge Install
I was looking at the Chrome Flush Mount (Popup) FuelCap and Gauge set ($195 MSRP) and was wondering if anyone has intalled one. If so, how hard is it to do?
Old 07-29-2007, 06:31 AM
aframe2's Avatar
aframe2
aframe2 is offline
Default RE: Flush Mount (popup) Fuel Cap and Gauge Install
I just bought a set, I haven't installed it yet, but I got mine from Chicago Harley for 169 dollars.
Old 07-29-2007, 06:44 AM
geno3j's Avatar
geno3j
geno3j is offline
Even if you have a hard time walking and chewinf gum you can knock this simple task out in 45 mins to 1 hour. Nothing to hard about it.
Trailfndr's Avatar
Trailfndr
Trailfndr is offline
Install was easy ( i am NOT a mechanic) Directions are clear and straight forward. Took me about an hour, taking my time.
Only problem I have is after 3 months, the leds on the fuel gauge started going out. Now have 4 not working...I am not happy about this.
Old 07-29-2007, 11:13 AM
cojohn31's Avatar
cojohn31
cojohn31 is offline
6th Gear
Same here as trailfndr easy install LED lights stop working after two or three months.
Old 07-29-2007, 11:29 AM
Chief101's Avatar
Chief101
Chief101 is offline
I read several posts where water was getting inside the tank with the flush mount set. Has this improved? id love to have a set too, just kinda got spooked with the water issues.
Old 07-29-2007, 03:54 PM
NoVaThunder's Avatar
NoVaThunder
NoVaThunder is offline
I have a set installed and as far as the water thing goes. The rubber seal around the gas cap is recessed a little so that allows a small amount of water to settle on top of that seal when you wash your bike. If you blow the water out with a leaf blower or a compressor after you wash the bike or just go for a ride you shouldn't have a problem. If you wash the bike then open the gas cap immediatelyyou will probably see a small amount of water. I use a leaf blower to dry the bike and haven't had any problem with water.
Old 07-29-2007, 06:32 PM
Chief101's Avatar
Chief101
Chief101 is offline
Thanks for the info. They really do look slick.....if the water problem is as minor as that, looks like I may be installing a set soon.
Old 04-08-2010, 04:20 PM
Jhorton's Avatar
Jhorton
Jhorton is offline
I am guessing that even though this post was back in 2007, others like me know that these are pieces of crap. Mine lasted about 2 months. Now only the fuel pump icon lights up and one light blinks constantly. When turning on the ignition, all the lights light up once. Then only one blinks. What a piece of crap.
Old 04-08-2010, 04:47 PM
oct1949's Avatar
oct1949
oct1949 is offline
read that they go bad fast for several yrs in here..
Quick Reply: Flush Mount (popup) Fuel Cap and Gauge Install
