SE slip-ons
RE: SE slip-ons
I had the 07 Se's and yes they are louder then stock but still very quiet. Performance wise they are a waste of money as they are still way to restrictive. Get a set of rush mufflers, they have interchangable baffels that will suit your sound and performance taste at the same time.
RE: SE slip-ons
thanks guys!! the main reason I want something else is this Fuelpack has to go. I can't get it right. My plugs look ok but no blackening of the exhaust pipes at their tips makes me believe it is running lean and it is bothering me. I took the pulgs out and they look ok but i know it isnt right. I thought going to the SE's would be ok to do without a fuel management system and I am just tired of worrying about this. I may just go back to stock until I feel like trying it all over again : (
RE: SE slip-ons
If your sick of the fuelpack, then drop it and try running a good slipon. As long as your not changing anything else you should be good to go.
I had some luck finding a set of new in the box HD SEII slipons on ebay, great sound, deep but not too loud.
Good luck, its easy to get frustrated sometimes. Try to listen to a few other bikes to get a ballpark idea of what sounds good to you. Keep in mind it may be a little different on your ride.
RE: SE slip-ons
ORIGINAL: drrandall1
SE slip ons are a waste of money
RE: SE slip-ons
Larry:
If your plugs are looking OK, I wouldn't worry about being too lean. The end of the tailpipe is not a good indicator of mixture unless it gets sooty, which means you are too rich.
If you are changing mufflers because the Pythons are too loud, fine. But if you are changing because you think you are running too lean, yet your plugs say you are not, then you need to think about this a bit.
