Questions on features
The FOB is only required if there is a security system installed on the bike. If there is no security system then you only need a key to lock the ignition and fork.
So, the 2016 should only have a FOB if there is a security system installed on the bike. If you can turn the ignition on and start the bike with no FOB then the bike does not have a security system. If it does have security and you do not have the FOB it would ask you for the PIN when you turned the ignition on.
