Characteristics of wide vs. narrow rear tire?
Wide rear tire
My 2019 Fatboy 114 came with radial 240/40R!18 Michelin on it. The look and ride are great. It appears to also has great traction. The cornering is good but only after learning that you have to push the bike over in the sharper turns. It took a while for me to feel confident. Also tire pressure seems to be very important. Manual calls for 42 psi. Even 3 lbs lower makes the rear squirm a bit. All good with the correct pressure.
As a drag racer that is always hunting for the optimum traction I can tell you that more contact patch does not necessarily provide more traction. It really only improves traction IF the structural limits of the rubber compound is exceeded by the torque applied to the tire as spreading the force across a larger section of the surface means that each molecule of rubber has less force to handle. What we call traction is simply the friction between the road and the tire and the two primary factors that increase traction are weight and coefficient of friction. Traction is independent of contact area. We get this from Amontons Laws of Friction.
Here's an article that explains this concept a bit better and while the context is motorcycles it applies to cars and trucks as well. Want better traction, run stickier tires. https://www.stevemunden.com/friction.html
My 2008 FXST had a 200 wide on the back and a 90 on the front when new and it never felt like a good match. Ended up beefing up the front rim so it can take a 120 0r 130 and it seems much better,especially in the wet. I have found with a fat 200 back tire, counter steering is the best way to ride fast through corners.
On the other hand my old 84 wide glide shovel shovel has a 130 rear and 90 front and handles superbly.
Not really sure where this modern inkling for fat tires comes from, maybe it is to suit the modern fat rider.
Most go to a wider tire for looks. Nothing wrong with that. Over doing it can cause issue handling and on wet roads . Most can deal with the change. It is a lot about Pounds per-square inch There is to much and to little the best comes in the middle some where.
When HD went to the new frame on the touring bikes wide tiers were do. They worked out well. 130 to a 150 is not likely to have a big effect on most riders.
