Samson pipes and air filter
richardgalbraith68 (03-09-2020)
Deluxe760 (01-27-2020)
I'd say don't sweat the details on this one. Go getchya some Samson fishtails, and an air cleaner ya like the looks of. I don't think the difference in umph, between any of the choices/options, are gonna amount to squat. Don't forget a tuner! I just use easypeasy FP3s on mine. Run great.
yes I’m getting the thunder max tuner to go with the pipes Samson running a decent promo on pipes and tuner.
The following 3 users liked this post by 1scruffynerfherder:
those are 36”? I was thinking of doing 33” but your bikes swaying me towards longer.
Here you go. These guys were great, even pre-programmed the map for my Dynojet to go with the air cleaner and pipe setup. I’m glad I went with the 36” pipes, 33” would have been too short I think.
Air cleaner link
Deluxe760 (02-05-2020)
A couple Question for you guys running true dual fishtails.
How far past the rear fender does the start of the curve up portion start?
How far out from the fender (or rim/tire/hub...) is the exhaust (edge/center...)?
So far I have not seen any pictures straight on the side or back so I can tell.
I have have hard bags and the suppliers do not seem to have detailed information on position (because generally they do not have hard bags).
If I can find a set that will fit and not extent to far I would like to try them.
Thanks
Thanks
Thanks
Thanks
