2003 fatboy front headlight?
It is pretty easy to swap it back to stock look.
Someone likely added a kit like this https://www.jpcycles.com/product/310...conversion-kit
And you will need to get a kit like this and add a stock headlight housing which are readily available. https://www.jpcycles.com/product/230...rome-fork-tins
soldierbot (03-12-2019)
Cool thxs! I just home the wires are not spliced or cut, I dont want to be repairing that
Not just any I think you need a specific trim ring that fits over the stock ring. I "think" this is the one if you have an HD nacelle: Part Number 69733-05.
https://www.harley-davidson.com/stor...-11-6973305--1
Found this one on Amazon.. says is fits Freight Train Headlight Nacelle? I wonder if this is ok?
HDJoey,
The other posters are correct, that is what is called a front nacelle (often called freight train front end). It is simply a chrome plated cover that goes over the headlight and makes everything look like one piece. It is an upgrade and not "stock" on FatBoys, although it probably is a stock H-D part.
Please PM me if you are interested in selling it cheap.
HDJoey,
Cool thanks for the info!! If I decide to remove it I will contact you for sure
