Progressive drop in fork kit, what oil?
Old 02-22-2019, 03:07 PM
mshred's Avatar
mshred
mshred is offline
Default Progressive drop in fork kit, what oil?
What weight fork oil are you guys with progressive front fork drop in lowering kits using? My forks are apart for powercoating, reassembling and wondering what oil would be best. I ran stock oil this past season
Old 02-22-2019, 03:23 PM
RANGER73's Avatar
RANGER73
RANGER73 is offline
Received 6,323 Likes on 3,179 Posts
Depends on what you want. I'm a big guy so I use heavy fork oil. You have to try different oils and even mix the 2 if you need to.
Old 02-22-2019, 03:33 PM
mshred's Avatar
mshred
mshred is offline
We have garbage roads here and I did a LOT of bottoming out..thought maybe a heavier fork oil would help that? Bike handles fine though, so i dont want to stiffen them up too much
Old 02-22-2019, 06:06 PM
RANGER73's Avatar
RANGER73
RANGER73 is offline
You won't feel the difference
Old 02-22-2019, 07:12 PM
Big Mule's Avatar
Big Mule
Big Mule is offline
My progressive mono-tubes called for 10W oil. 5oz. In each tube.
Old 02-23-2019, 06:39 AM
RANGER73's Avatar
RANGER73
RANGER73 is offline
That's a starting point and just a suggestion. Different factors require different ways to do things. That's why there are different options available.
Old 02-23-2019, 10:20 AM
jam436's Avatar
jam436
jam436 is offline
The oil in Progessive Monotubes is strictly for lubrication and has no effect on dampening.
That's why there's so little of it - only a few ounces as opposed to filling the tubes.
Old 02-23-2019, 06:48 PM
04FXDI's Avatar
04FXDI
04FXDI is offline
I spoke with my indy today regarding the drop ins from Progressive, I was going to front drops and rear shocks, he said its definitely going to stiffen the front end, you won't experience the nose dive in a heavy braking situation, but you will notice a stiffer front end. For me, I opted out, I like my smooth ride, JMO.
Old 02-24-2019, 06:54 PM
mshred's Avatar
mshred
mshred is offline
So if that's the case, then standard fork oil should do it? The instructions it came with mentioned to only follow the harley standard procedure for fork oil service/amount.
Old 02-24-2019, 06:55 PM
mshred's Avatar
mshred
mshred is offline
Do you mind elaborating a bit? Not to sound ignorant or stupid, but what would factor as changing to different fork oil weight besides size/weight of the rider?
Quick Reply: Progressive drop in fork kit, what oil?
