Stripped out springer risers
Hey guys, I have a 97 springer softail. My problem is my risers loosen about once a month and when I tighten them they eventually strip out. I already heli coiled them and used red thread locker. Where can I find aftermarket risers that will fit and still use bushings for vibration? Thanks for any info. S.C.
This is not an answer to your issue, but you can replace the chrome plate on top of the tree and use standard risers and bars. My 01 Springer came with different bars and risers. My problem was finding bars to specifically fit my bike so I could use my OEM risers because I like the look. BTW---any machine shop should be able to fix your problem, but I don't know if it would be cost effective.
Received 3,345 Likes
I have a 2001 Springer, there is the difference between the Springer and other Softail risers... Ref: mounting bolts #10/springer versus #1/Softail
Although I've never tried, I don't think you can make the Sringer mounting bolt (#10 in the pic) work with regular softail risers.....
No you can't make that bolt work with other softail risers----BUT---I have an extra Chrome adapter plate that works using a standard bolt that bolts the adapter plate to the top of the tree and it has the standard mounting system for regular bars.Standard risers will bolt to the plate with bolts that come up from the bottom of the adapter plate and bolts the risers to the top.
Hey thanks for the replies. I changed my buckhorn's out for some Todd cycle bars. I like the look much better than stock. I have shaved down the caps and the risers for the clamping Force but after a while they loosen and when I tighten them up one of the cap bolts stripped out again I'm looking for OEM style aftermarket risers that are made from better material than original. I am new to forums but I'm going to try to attach a pic of my bike and my OEM Riser they are different than regular Softail risers. I have seen after markets without the bushings. solid mount but I might get too much vibration on my bike. Thanks
https://www.hdforums.com/forum/softa...1-softail.html
when I was trying to sell stuff. A picture of the adapter plate and risers are included.
