Sport Glide, risers and cables oh my...
Old 12-06-2018 | 10:16 PM
14IronCross's Avatar
14IronCross
Originally Posted by Landshaper
Hey 14,
any more pics with that 5.5 windscreen? Does it help with the head buffeting? I’m 5’ 5” and thought about getting the Gustafsson 6” in dark bronze
Absolutely Love my Sportglide!
I am 5 10 and it takes wind off my shoulders.
Buffeting will greatly depend on your helmet, i have ff Arai and no Buffeting till over 80 mph.
I think Gustafson is super over priced.
Landshaper (12-08-2018)
Old 12-07-2018 | 06:38 PM
14IronCross
here are more pics of the windshield as requested
soldierbot (01-12-2019)
Old 12-08-2018 | 08:17 AM
Landshaper's Avatar
Landshaper
Sweet!!
Old 12-08-2018 | 07:08 PM
Pragmatic's Avatar
Pragmatic
I put these 10” drag bars on and didn’t change any cables, the brake line is tight however...
Sven Bobby (10-27-2020)
Old 01-12-2019 | 07:40 PM
felix27's Avatar
felix27
I just want to let others know I installed the 6” HD risers with stock bars with existing wiring. The clutch cable moved to the front of the bars. The brake cable is a bit short but is driveable for now. Eventually I will change it to +2” or so.
One minor modification was needed. The risers base diameter was larger than the stock riser and would not fit in the hole so I got some washers from Lowe’s and that seems to be fine otherwise the riser base would make contact where the bars get bolted down. Just one washer each side. This brings the bars closer to you.
Old 01-12-2019 | 08:26 PM
felix27's Avatar
felix27
Admin, please move this to softtail 2018+ forum.
Thanks
Old 01-21-2019 | 01:29 AM
apx07's Avatar
apx07
Hi guys, haven’t posted for quite a while and not since I bought the Sportglide (from a Fatbob). Hello again!
i just fitted the 6 in risers. I think I could have got away with not extending the wiring but I did put extensions on. You really only need a couple of inches to be comfortable so the shortest extensions would be best. The brake line is at full length but looks OK. The clutch cable however appears too short. At full right lock the cable is straight down in front of the bar and at a slight angle on the control housing. I have ordered one 2 inches longer to be sure...
Old 01-21-2019 | 10:45 AM
Bochawa72's Avatar
Bochawa72
I put some 12" San Diego bars on my 19 and all I had to do was extend the upper brake line. Granted these are about 10" narrower than the stock bars so most of the wiring just goes up instead of out now. I got a 26" upper brake line because it was all I could find in SD but I think a 24" would be perfect.
Old 01-21-2019 | 11:36 AM
14IronCross
Nice,
How much did the 26" brake line cost you?
Old 01-21-2019 | 11:44 AM
Bochawa72's Avatar
Bochawa72
Originally Posted by 14IronCross
Nice,
Oh yeah…. about $70 for the line and another $70 for an adapter. Turns out the upper brake line was not available anywhere with a male fitting on the lower end. I was pissed but not surprised.
Quick Reply: Sport Glide, risers and cables oh my...
