Heaviest weight the Fatboy can take?
Old 10-26-2018, 12:39 PM
OKMICK's Avatar
OKMICK
OKMICK is offline
Received 36,879 Likes on 17,363 Posts
Gnaw off your arm to reduce weight.
Old 10-26-2018, 12:40 PM
Fblo1690's Avatar
Fblo1690
Fblo1690 is offline
I had a 2012 Fatboy. Before i got my life together I was 325lbs and the wife was preggo @ 275. Soooo close to 600? We rode everywhere on that bike. And I had 18” apes. It’s just a matter of adjusting. Kind of like having a 10” steering wheel vs a 24” steering wheel. Just takes an adjustment and a little common sense.
Dos Equis (10-26-2018)
Old 10-26-2018, 01:38 PM
screaminroadking's Avatar
screaminroadking
screaminroadking is offline
Gonna have to rename the bike at least temporarily to fat girl. Also might want to install saddlebag supports.
(sorry couldn't resist it's my turrets syndrome)
Old 10-26-2018, 01:40 PM
hattitude's Avatar
hattitude
hattitude is offline
Received 8,190 Likes on 4,398 Posts
Originally Posted by Dos Equis
Sorry for my ignorant question. What's the heaviest weight the Fatboy can take? I met this Lady that wants to go on a bike ride but she's like Tess Holliday without the tattoos! Approx, 320 Lbs. Will the Fatboy take our total weight? I am 190Lbs. Do I need to adjust the suspension? Please, no fat women jokes. I love chunky. Thank you.
If you really want to know...
There is a manufacturer's label on one of your front down tubes. It will have the date of manufacture, your VIN, and the gross vehicle weight rating (GVRW). That is supposed to be the max weight of the vehicle and all payload (passengers/cargo).
According to my '03 Heritage softail, you would be overweight by almost 100 pounds.
Here is my label:
Per my label, the GVWR is 1160lbs. I have not actually weighed my bike's "running weight" (weight of the bike with full fluids, minus any passengers/cargo) but the vehicle running weight of my bike is reported to be 738lbs. So the GVWR (1160) minus the running weight (738) leaves my bike with a total payload capacity of 422lbs. You and your girl, minus any cargo, equal 510 lbs. It could be unsafe for you to take her for a ride on my Heritage.
I suspect your softail will be similar. I sincerely doubt it's a 100lb difference.
So, you can find out the bike's limits, know the possible risk, so it's now up to you, to decide how much risk you're willing to take.
If I were you, and decided to take her for a ride, I would make sure the tires are in good condition, within their serviceable life (generally 7 yrs), and inflated to max pressure for max load capacity. In the long term, I might look for tires that would fit the bike with higher load capacity, but that's just one piece of the GVWR puzzle.
Good luck with your decision...
GrizzLee (07-05-2021)
Old 10-26-2018, 01:51 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 48,986 Likes on 17,897 Posts
Few old buddies of mine and their wives ran 500-600lbs or so together and I mean big people & rode the 90's Fatboys, go easy on corners and speed bumps is all, stock shocks will bottom out .
Better you than me partner, thanks for taking one for the team.
the jacobite (01-10-2021)
Old 10-26-2018, 01:53 PM
Tom84FXST's Avatar
Tom84FXST
Tom84FXST is offline
Received 20,080 Likes on 5,817 Posts
I don't think you will be far enough over the weight limit of the bike to matter...but what you really need to check out is the weight limit of the tires...especially the rear...
I betting a blow-out at highway speed with 510 lbs of passengers will not be pretty.
A standard dunlop only has a load index of 67...I would look for something higher...
Old 10-26-2018, 04:56 PM
cdonis's Avatar
cdonis
cdonis is offline
I've had 460 pounds on my breakout. I like big butts. Give it hell bro.
Old 10-26-2018, 07:05 PM
Juan L's Avatar
Juan L
Juan L is offline
Moderator
Received 20,117 Likes on 10,260 Posts
Cue Sir mix-a-lot
Old 10-26-2018, 09:32 PM
AussieDog's Avatar
AussieDog
AussieDog is offline
Ride how ever you want.....but dont put her on top
Old 10-26-2018, 10:08 PM
cdonis's Avatar
cdonis
cdonis is offline
Originally Posted by rwhisen
you caught that huh.....lmao
Quick Reply: Heaviest weight the Fatboy can take?
