On the left hand switch block the top button closest the bike that cycles through the different read outs ,when you get to MPH there hold it down till it changes.
You manual has how to do this in it.
I switched on the ignition with the key fob near and cycled the trip switch until it showed the total miles. Holding the trip switch down at that point changed the display to KPH. I did a video if I am able to upload it. Cheers all for the help.
I hope this hasn't been covered elsewhere as I did do a search. My speedometer seems to be only calibrated in MPH, although that is in the digital display of the speedo. The numbers around the dial go up to 210 so I am assuming that there is some way of changing from mph to kph. I can't find it in the owners manual. Anyone have any idea how to change it for a pending trip over the channel?
Your speedometer is in kph even though it shows mph in the digital side which might be just for the odometer.
210 mph is more than 300 kph (I don't think your bike it THAT fast)
