Just noticed that while riding between 55-65 MPH, the bike has sort of a wobble when I let go of the gas.
I did a bit of research on the web, and they say it could be the steering head bolt is loose?
Any suggestions? Driving me crazy!
My 16 Deluxe had a bent rear wheel which caused a wobble/hop, if you can put it on a cycle jack to check the lateral runout on your rims, check spokes and tire condition, do a fall away check that will let you know if you have to adjust the head/neck bearings. Ride safe, Good luck.
Check fallaway. But I bet it is the tires. Those needle bearings in the steering head will last a lifetime if they were right a while back and you do not use your Harley for ramp jumping.
Found the culprit...loose rear spokes. My local mechanic carefully tightened each one, now rides straight as an arrow! I was happy he did not have to take off the wheel or tire off.
