Any plate relocation kits for 18+ Fat Boy/Breakout?
Old 09-09-2018, 06:22 AM
TwoForty's Avatar
TwoForty
TwoForty is offline
Mchad (09-09-2018)
Old 09-09-2018, 06:48 AM
Mchad's Avatar
Mchad
Mchad is offline
Received 3,538 Likes on 2,145 Posts
Interesting. I found this on eBay. $25 of cheap Chinese manufacturing. However it does look pretty perfect. Aluminum, so no rust, i’d probably have it properly powder coated just for the hell of it, but for the price I don’t think it can be beat...
I’m only wondering if the top edge mount of the plate would cause it to sag or bend under the constant bumping around.
Old 09-09-2018, 06:49 AM
Mchad's Avatar
Mchad
Mchad is offline
Originally Posted by TwoForty
Ha! I just saw that as well! (See above)
But looking more closely at it, it looks like it would hit the tire under hard bumps (not uncommon here in the land of **** road NY) clearance looks too tight.
Old 09-09-2018, 08:23 AM
K9F's Avatar
K9F
K9F is offline
Originally Posted by Mchad
..Steel really? I would have bet it was plastic. Interesting. I’m wondering if it may be worth it, but isn’t the UK/EU plate dimension very different from the US plate? If I could make it work, I’d be willing to pay what’s necessary.
Apologies mine won't work for you as it is 2017. Nevertheless if you are registered with the Harley-Davidson Information Portal there are many rear licence plate holders. Here are some of the part numbers anyway:
67900370
67900384
67900397
59500108
67900147 Mine is this part number for Breakouts 2013 onwards.
There are quite a few more. The hardware reflectors etc will also be required.
https://serviceinfo.harley-davidson.com/sip/index
Register with the above, put in your exact model and see what is available to you in the parts. Good luck and hope you find what you want.
Mchad (09-09-2018)
Old 09-09-2018, 08:55 AM
Mchad's Avatar
Mchad
Mchad is offline
67900370
67900384
67900397
59500108
Perfect. Thanks very much. I am indeed registered there, and found the parts necessary. All in, about $95. Far less then I expected. And all seem to be available.
Much appreciated!
beantownhd
08-15-2019 01:25 PM
nicktown
07-14-2017 01:53 PM
Felix 808
2014-2023 Touring Models
14
03-17-2015 09:21 PM
DougYITBOS
08-06-2012 08:03 PM
RandyS
01-26-2009 10:54 AM
Quick Reply: Any plate relocation kits for 18+ Fat Boy/Breakout?
