Extreme Flow vs. Heavy Breather Air Cleaners
dont know what the MoCo gave you for final drive gearing, but with the newer twin cam bikes, I think 06 and up... They swapped out from what was a much better combination. So many of us went and changed it back.
The result was through the roof.
Can’t imagine needing more low end torque then what ai have now.
Something worth checkin into IMO
Received 4,233 Likes
Not all Stage I's are created equal. Here is a report on the differences between a typical Stage I and a Stage I that really can add some performance, engine longevity and tune stability. Report LINK
The Outlaw 636v will out-perform either of the two A/C's asked about. It is also less expensive, lifetime warranty, and Made in the USA.
On another note, we've never heard of and EBS voiding a warranty. But if one is worried about that, just remove it if you ever need to go in for warranty work. Why compromise performance and engine longevity for a worry of what may happen when you can spend 30 minutes making it a completely non-issue?
Top Performing Air Cleaners LINK
__________________
Win Up to $350.00 Cash from DK Custom This Month, Click HERE to see How!
DKCustomProducts.com
Heavy breather needs a heat shield or its sucking hot front jug air.
All the other flat breathers would need an even bigger heatshield to almost get the same effect.
Heavy Breather moves the actual intake a little farther away from the heat pump under your gas tank
I I have one. Doesn't bother me but does interfere with my leg but not an issue for me. I found an Arlen Ness it I had to have because of the looks. I paid 400 minus a discount but you can buy the exact same one on the bay for 100.
