Stand on 2018 sport glide problem
I have my sport glide 2018 since may
like everything about it but one thing
the stand : the angle is very staigh stand is short and flimsy never dropped a harley before
i dropped this bike the first week by just moving it stand pop's up quick
i was washing bike turned the wheel to wash stand poped up again bike almost fell on me
really a flaw in this design.
need to find a solution
^^^ Exactly. Has to be used/treated differently than other kickstands. Once the habit is developed it's not an issue. Just have to be sure to look, move it all the way forward, pull the bike back as you are laying it over onto the stand, and all is good.
I'd guess that when you turned the bars and had the bike come over on you that you hadn't set the stand all the way in before letting the bike go when you originally set it. Probably lucky that it didn't all on its own before you were standing next to it later. They're trickier than past stands for sure, a pita really, but useable.
Had many flh previous years had a softail in 1986
kikstand's where never an issue and even where very secure
with this bike i never feel secure it is so easy to pop up the slight movement of the bike and it does
i now sit on the bike everytime i move it in my garage
if harley does not come out with a fix i will try and find someone who will .
The stand is definitely worse than on older HDs - but it does the job. As other have said, push it forward with your boot as you tilt the bike over and pull back. The bike locks on the stand and it is deceptively strong.
One thing to be aware of though - on my bike, the c-clip holding the clevis pin that the stand pivots on came off and the pin came up through part of the bracket. This made the stand fee very loose and wobbly. I fixed it with another c-clip, but you might want to check yours just to see if this is your problem.
A long term fix for this would be to drill the end of the pin and put a retaining ring through it.
