Will 69734-05 (headlamp trim) fit a 2018 Heritage?
Ok so having seen the close up of the mounting tab on the bottom edge it would seem not
the Heritage has a bolt that ‘pinches’ the stock trim closed around the headlight case
so, how about 69733-05?
its listed for touring models and Softails with ‘freight train nacel’ But looks like a similar ‘pinching bolt’ fitting as the Heritage’s stock trim
Anyone got any knowledge/experience?
69732-05 is for the Passing lamp trim and 69733-05 looks like it should be the matching Headlamp trim.
If the Passing lamp trim fits a bunch of '18 models I can't believe the Headlight trim is made only for the one bike.
I guess you can always buy it, try it, return it if it doesn't fit.
Post you findings.
Thanks
Post you findings.
Thanks
Visor style headlamp trim for 2018 Heritage
I'm coming up empty here
Looking for a visor style trim for my 2018 Heritage (ideally black) but nothing seems to fit
I tried the 69733-05 but it's way too big (fits the touring bikes with the 'freight train nacel)
I also looked at the 69734-05 but it has a different fitment (the Heritage trims have a clamping bolt, whereas this one uses a single bolt fastning front-to-back)
Anyone had any success?
bobbyd3
08-01-2007 07:09 PM
