Anyone got '07+PCIII+K&N+V&H with no O2's
I had a dyno tune +PCIII + K&N Filter installed to a 07 flstc. The 02 sensors were disconnected from under the seat. There are wires hanging near the air filterfitted with a resistor.The engine light remained on but theHD dealer laterprogramed it to stay off using alap top.I had modifiedstock pipes on. All the above seems not carefully or expertly made. Is this the normal procedure for PC's on 07's? I have just purchased V&H Big Shots Long pipes and would greatly appreciate right advice on having thebike properly set up with out all the disconnections, or is that it?
RE: Anyone got '07+PCIII+K&N+V&H with no O2's
Well, I just went through this a couple of weeks ago. First of all, PCIII is designed NOT to use your O2 sensors; they provide O2 sensor eliminators. If you bought "07" pipes with the O2 sensor bung hole, then you will have to find something to plug it up with...I used the old O2 sensor and just hid the wires. DO NOT CUT THE WIRES OF YOUR O2 SENSOR...YOU DON'T KNOW WHEN YOU MIGHT NEED IT!!
Once you get your new pipes, load the new map for the PCIII onto your laptop (you can get it from Power Commander's site) and then you should be rolling. Pretty simple.
Tim
Tim
As above, u will need to sensor eliminators (o2) if you are in the US or 4 sensor eliminators if you are in Australia or Europe (active exhaust and air intake). Plugging these in will make the engine light go out with having to program it not to.
Regards,
Dean
Regards,
Dean
I see, thanks, so I leave everything hanging there onboard butdisconnected. I wonder why 02's are not part of the PCIII set-up. I'll just leave it to theones that knowto tear bits off it as long as the bikegoes alright, looks good and feel alright!
My previous Harley was a 1976 Sportster in 1983. Some things changed some things don't.
I do. Put on V&H Big Shots Staggered and eliminated the O2 sensors. Put the PC III and S/E air cleaner with a K&N high flow filter. I had mydealer dothe install. I gained 16% in Horse Power and 20% in Torque. You can't believe how much better the bike performs now. I'm really glad I used this setup. It's worked out great for me.
ORIGINAL: dmac1968
Regards,
Dean
Regards,
Dean
Ditto to the above, just installed PCIII, took out the O2 sensors with the eliminators, and I have to tell you, the difference is amazing. I'm looking to pull the sensors and wirign and just put in a plug. I'm sure they are out there. Not very "green" but dammit, the bike runs as I think it should with all kinds of torque and power.
o2 cents,
Eddie
o2 cents,
Eddie
Let me see if i got you right...
When I'll put the PCIII + Arlen Ness a/c + Rush slip ons I'll have to connect the O2 elimentorsand THE ENGINE LIGHT WILL GO ON FOR GOOD?
Can I set the stage 1 without disconecting the O2 so the engine light won't go on?
I don't want the engine light to on and I don't think the dealer here in Israel will knowhow to program the
bike not to turn engine light (they don't know how to put PCIII on harley )
Thanks for your advice
